Anyone have a use for a used gauge cluster? It no longer has the connectors, but still has plenty of wiring to work with. The mounting tabs have been cut off so it would fit in a narrower area, so the housing won't be any good for a stock bike. The lenses have some foggy spots, but everything is still visible. All the gauges work. It reads 34,350 miles on the odo. I also have a newer speedo cable I no longer need.
Would be great to salvage parts out of for an existing gauge set.
If you can cover shipping, it's yours!
I am in need of a rear brake switch...so I'll gladly trade for that
