everything was purchased new, except the throttle bodies of course. the fuel rail has been silversoldered, the entire system pressurized and does not leak. new o-rings on the injectors
r6 throttle bodies: ~100
k&n filters: ~120
http://www.amazon.com/gp/product/B00062 ... UTF8&psc=1
walbro 255 fuel pump and install kit: ~110
http://www.diyautotune.com/catalog/walb ... p-312.html
v3 microsquirt: ~340
http://www.diyautotune.com/catalog/micr ... p-131.html
all sensors and pigtails are included (IAT,ECT, MAP, r6 TPS). I spliced in a GM MAP 1bar sensor over the r6 one, up to you if you want to use a newer style (smaller)
will sell outright, or consider trades for engine parts (I have a few spare bikes): complete carbs, rebuild kit, undercut transmission, whole running engine, etc
let me know if you have any questions. I except this to be listed for a while, so if the ad is still up it's still available
edit: you do NOT have to modify the frame for these to fit. an older writeup said you did, these will fit in an orig frame just fine
