The following is a list of FZR400 & 600 parts that I hope to find new garages for.
*** Items are for the 600 unless otherwise specified.
*** Items for the 400 only will be noted as such.
*** Items that can be used on either bike will be noted as such.
Please bear in mind that I am still going through everything. The prices that I've listed are kind of off the top of my head. If I come across a part that I think may need a reduced price due to the condition of the part, I will try to adjust fairly. I just wanted to get this list out there in case anyone was in need of something.
I will be putting up pics in the gallery as time permits. Where there are duplicate items, they will be numbered for clarification. Here is the link:
https://picasaweb.google.com/113255888437831917309
There are a number of items that I am planning to keep for now so if you don't see it on this list, it's probably not for sale. I will continue to try to keep the list as accurate as possible.
Again, if any of the prices seem out of line, please let me know and maybe a different price can be worked out.
Let the games begin!
Prices do not include shipping unless otherwise noted
******** Engine / Fuel / Drive *******
49-State intake cam #1 ------------- FREE!!!
**** (broken bearing -
49-state exhaust cam #1 ------------ $10
49-state exhaust cam #2 ------------ $10
CA exhaust cam #3 ------------------ $10
enrichener (choke) lever ------- $5
enrichener (choke) cable #1 -------- FREE!!!
enrichener (choke) cable #2 -------- FREE!!!
enrichener (choke) lever #2 -------- FREE!!!
**** (broken lever) ****
sprocket cover #2 --------------- $10
*** no actuator or dampers ***
*** actuator spring pin broken off - would need to be drilled out and replaced with a screw ***
*** other than the above, near mint looking cover ***
heat shield ------------------------ FREE!!!
intake boots ------------------- $10 (x2 - left, left)
600 steel rear sprocket (530) ------ $10
*** (according to PO: <2000 miles) ***
600 OEM steel front sprocket (530 / 15) - $5
600 OEM steel rear sprocket (530 / 45) - $10
400 OEM steel rear sprocket (428 / 55) - $10
400 Sprocket Specialties aluminum rear sprocket (520 / 44) - $15
*********** Carburetors ***********
Pre '92 600 carburetors set #1 ---------- $75
* excellent condition / near bolt-on
* float bowl cover o-rings appear to be in very good shape
* replaced most of the rest of the round o-rings
*** Needs ***
Jet tower o-rings
*** Has ***
stock main jets (107.5)
stock needle jets (emulsion tubes)
Currently has Factory Pro needles but I'm taking these out and putting them in my bike. I will put the DynoJet needles that my bike currently has into these carbs...
NOTE: These carbs WILL work with ANY year 3HE FZR600. The only caveat is that you need to be sure to have the correct throttle push cable.
*********** Cooling System ***********
thermostat & radiator hoses---------- $10
coolant reservoir -----------------$10
coolant reservoir ----------------- $10
**** (no cap) ****
************** Front End *************
triple tree ------------------------$10
fork lowers ('89) ------------------- $10
OEM fork springs -------------------- FREE!!!
top triple clamp -------------------- $5
************** Rear End **************
OEM shock ----------------------- $10 - SEE PICS
dogbones ------------------------ $10
************* Electrical *************
starter solenoid #1 ----------------- $5
starter solenoid #2 ------------------ $5
**** (missing rubber mount) ****
ignition switch w/key #1 ------------- FREE !!! (400 or 600)
**** no key ****
ignition switch w/key #2 ------------- $10 (400 or 600)
ignition switch w/key #3 ------------- $10 (400 or 600)
VR/R plate ---------------------------- FREE!!! (400 or 600)
VR/R plate #1 ------------------------ FREE!!! (400 or 600)
************** Bodywork **************
gas cap ring #2 ----------------------- FREE!!!
*************** Control **************
clutch cable --------------------- $10
switch pod - right (cut-off) --- $15 (400 or 600)
switch pod - left (signals) ---- $15 (400 or 600)
clip-on bosses #1 -------------- $10 (pair)
rear brake lever #1 ------------------ $5 (400 or 600) - SEE PICS
shift lever #1 ------------------- $5 (400 or 600) - SEE PICS
pilot peg brackets #2 ---------- $10 (pair) (400 or 600) - SEE PICS
throttle pull cable --------------- $5
throttle push cable (pre-'92) -------- $5
throttle push cable ('92+) ----------- $5
clip-on bosses #2 -------------------- $10 (pair)
handle bars #2 ----------------------- $10 (pair) (400 or 600)
**** (slightly bent) ****
rear brake lever #3 ------------------ $10 (400 or 600)
**** (aluminum) ****
**** (slightly ground) ****
shift lever #3 (C quality) ------------ $5 (400 or 600)
shift lever #4 (C quality) ------------ $5 (400 or 600)
clutch lever #4 ----------------------- $5 (400 or 600)
**** (no ball end) ****
clutch perch #1 ---------------------- $5 (400 or 600)
**** (no clutch switch) ****
clutch perch #2----------------------- $10 (400 or 600)
400 clip-on bosses #1 (pair) ------- $10
400 clutch lever --------------------- $5
400 clutch perch -------------------- $5
Also have ~2 - 3 sets each of switch pods that I still need to go through. If anyone is in need, I will have a closer look at them to see what's available. Price will be dependent on their condition.
*************** Brakes ***************
4-pot front calipers ------------------- $15 (pair) - PICS PENDING
**** (Right one may need new seals) ****
**************** Seats ****************
rear seat #2 (C quality) ------- $5 - PICS PENDING
**** (missing strap) ****
