ignition advancer
Posted: Fri May 16, 2008 6:16 pm
by PIMPMYFZR
Is there anyone who has installed this or anyone who knows how to install ?
And is there any kind of step by step to install cuz i really have no clue how to do it , i seen somone had one on the archives but so much for that
Re: ignition advancer
Posted: Fri May 16, 2008 9:41 pm
by BILTIT
Which one do you have?
Posted: Fri May 16, 2008 9:52 pm
by ragedigital
There is only 1 that I'm aware of and that's by Factory Pro. You pull the flywheel, put the new one in and reinstall the flywheel...
http://www.factorypro.com/Prod_Pages/pr ... dvance_Kit
Posted: Fri May 16, 2008 10:14 pm
by PIMPMYFZR
yea its factory pro . got it from haunter wanna see what differnce at all it will have with a k&n airfilter and yoshi slip on
Posted: Sat May 17, 2008 3:52 pm
by megaloxana
If i remember correctly, you remove the flywheel and replace the key on the crank with the new key. Pretty sure you gotta have the offset to the left(when slot is on top of crank). Then just reinstall the flywheel. With an impact wrench should be no problem.
Posted: Sat May 17, 2008 4:35 pm
by PIMPMYFZR
What if I don't have access to an impact wrench and has anyone noticed any considerable differnce then from stock ?
Posted: Sat May 17, 2008 4:46 pm
by mpap
Dont have one on my FZR, Have used ignition advancers some flywheel,some electrically controlled, 5 degree ignition advance and IMO you will notice the difference, I have 3 degree advance on a 04 Kawi Prairie 700 4x4 and makes a huge difference, If i had one sittin around for FZR i would install, But i most likely wouldnt go out and buy one.Havent in the 5 yrs i have had FZR... Try it let us know...
Posted: Mon May 19, 2008 12:33 am
by megaloxana
PIMPMYFZR wrote:What if I don't have access to an impact wrench and has anyone noticed any considerable differnce then from stock ?
Well if not an impact wrench then you can hold the rear brake and use a breaker bar(i use my car jack handle slipped over a 1/2" socket wrench).
Not sure why I haven't done it yet ..So you get it done and convince me to do it
Posted: Wed May 28, 2008 10:06 am
by PIMPMYFZR
so i got my ignition advancer from Haunter . and im thinkin of tryin todo it tonight even though i dont have the right tools .. I've been looking up some stuff about the advancer and read a couple places that if im running hotter plugs on my bike its gonna run to advanced for my bike .. is this true or should i have nothing to worry about ?
Posted: Thu May 29, 2008 7:36 pm
by PIMPMYFZR
FINALLY GOT THE IGNITION ADVANCER installed and wow do i like my bike alot more now ...and it was free but i threw the guy 20 for hookin it up so fast
stock carbs yoshi slip on but man does this lil key tune the bike i swear i thought it was brand new motor
thanks haunter i guess that big bolt that came in the package was the fly wheel pulled
anyways if u think your bike is running like shit or boggin out on u .. this thing make it think otherwise atleast i think so......
Posted: Thu May 29, 2008 7:45 pm
by ThisEndUp
wish you could do a dyno run to see where any changes are.
I had an ignition advancer on my Sv650, years ago, and it didn't do squat.
I am curious about the effects of one on the FZR. It's a cheap enough and easy mod.
Posted: Thu May 29, 2008 7:59 pm
by PIMPMYFZR
wish i had a dyno and it is cheap i guess cost me $60 in all and thats having somone install it.. i dont think it gives you more power but my bike was idling kind of sluggish b4 now it seems as if somone smacked it and woke it up ..lolol
Posted: Thu May 29, 2008 8:05 pm
by megaloxana
Great that you had such fantastic results. Besides the idle, where would you say the most improvement was? lowend, mid or high?
Posted: Thu May 29, 2008 9:44 pm
by haunter
glad you are happy with it!
