Series is finished and Mossy is this years champ
Won by 66 points.
Round 6 two wins by 8 seconds each.Could have been bigger but wound down each race and started short shifting as motor had death rattle going on.
Pulled the motor out this morning and top end is off.Bore and rings look good but pins are worn and slopy.Conrods dont seem worn and wisco pins are good fit.
Took one valve out and stem seals are toasted.ordered more and get 1.5mm over bored in this week.Havent stripped bottom end so still looking for death rattle.Clutch seems ok but main nut was finger tight which wasnt what we expected.
The head is a mess with up to 1.5mm ridges around intakes so head work should grab lots more hp.Also exaust gasket were to large for yoshi system and had 2mm ridge so get some smaller ones to suit.
Cams and valves are mint and cam chain wasnt cause of rattle but will replace it.
New conrod bolts going in and conrods are 6/1000 with limits 6/1000 to 10/1000 so crank is measuring good.
Going to lap valves and order new shims.cams are mint condition.
fcrs worked well lower in rev range but not top end as they are rich so was racing with 3/4 throttle until over 100mph then opening full.
Ran without filters because the 3092 K&Ns need different stack to install so have ordered them aswell.
Will have it running again in a month or so then run it in at track day before dyno tune.
Next race should be December for the Tri series so expect alot more grunt.Hoping to see 160+ rear wheel,maybe even 170.
race footage 2nd race
http://www.youtube.com/watch?v=hw8Jmakzj8M
Ill do race one another day
