Some well priced ebay stuff
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
Brand new FZR400 rocker cover, dirt cheap. Might also fit a 600...?
http://cgi.ebay.co.uk/YAMAHA-FZR400SP-F ... 45eddadd8c
6 hours to blag a pillon seat for 99p!
http://cgi.ebay.co.uk/YAMAHA-FZR600-FZR ... 3ca8912660
Mega cheap wheel bearings
http://cgi.ebay.co.uk/YAMAHA-FZR600-FZ7 ... 3ef8ee3392
Good value stainless 4-2-1 front pipes, and the seller has Foxeye pipes available as well
http://cgi.ebay.co.uk/Yamaha-FZR600-FZR ... 20ae9313e5
Indeed, there's a phenomenal ammount of 400/600 shizzle out there at awesome value on the 'bay at present. For example, I watched a brand new unopened Dynojet kit go for £10.50 last night!
Good luck.
zero9243
Level 8.5
Level 8.5
Re: Some well priced ebay stuff
Post by zero9243 »
dont mean to rain on the bearing parade, but thatkid and I had to get some wheel bearings over the summer, and got the part numbers listed in the wiki. If you use those part numbers, you can get bearings for VERY cheap.
Upgrades:
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
Some very good deals on that side of the swamp...
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
nevertheless for listed bearings those are pretty cheap
Upgrades:
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
More...
http://cgi.ebay.co.uk/YAMAHA-FZR-400-FR ... 2ea9e56582
My wallet is fast emptying!
