no crank.possible cam missalignment?
Posted: Thu Jul 12, 2012 8:25 pm
so i got this 1987 yamaha fzr1000 its not stock imo. 100cc overbore ,n20,air shifter ect.
i received the bike with the cams allready out of it. and i am unsure if they are stock or not.
i downloaded the service manual for the 87 fzr1000 and installed the cam per spec. set crank to tdc aligned cam dots with the lines on the caps .
and when i tried to crank it over nothing i can hear the starter engaging . checked volts and load on battery its fine. so i pulled the starter and cleaned the brushes and bench tested worked fine. but it still wont crank over the damn motor.
so i pulled the cams and cranked it holding up the timing chain and it cranked fine. reinstalled cams and no crank at all.
could it be possible that the cam gear wheels were removed and placed in a different position?
any help would be great. Thanks
