92 fzr 1000
Posted: Mon Mar 19, 2012 10:08 am
by Allyn85
Does any one kno how to adjust the clutch
I am here: http://tapatalk.com/map.php?me1lkq
Re: 92 fzr 1000
Posted: Mon Mar 19, 2012 11:56 am
The joys of "maintenance free" hydraulic clutches - you don't. If you are having issues, the first step is to bleed it. You can also pull the slave cylinder off the mount (don't undo the hose! - and "work it", cleaning any mung that may be trapped in there. While you have the slave off, draw out the long push rod; a small ball bearing may try to escape along with the rod - don't lose it! Inspect the push rod for bending, galling, or the little ball bearing welded to the business end. No, really ...
92 fzr 1000
Posted: Mon Mar 19, 2012 7:28 pm
by Allyn85
Ok thank you
I am here: http://tapatalk.com/map.php?iwgop2
