I just put a new clutch in but I'm not getting the pressure in my leaver.
The clutch is movie ( cover is still off) but not as much as I'd like.
Any ideas?
Clutch
Re: Clutch
Do you have the pressure plate lined up properly? There is a triangle and a dot, one on the plate and one on the hub (I forget which has what). They have to be lined up, or the system doesn't work.
