fuel pump
Re: fuel pump
Check your voltage; your VRR may going, which will kill other, more expensive parts. The 1ks aren't as vulnerable to VRR failures as the smaller fizzers, but it happens.
Re: fuel pump
So just check to see if proper voltage is coming in? Also, I've seen kits on rebuilding the pump, asst they worth it?
Getting better
Re: fuel pump
Put a Mr. Gasket pump on. On with about 3-5 psi they work great no flooding the carbs and last for a long time! $45.00 comparred to the oem $400+ pump
