Bought a 1991 FZR1000 with a box of different jets and springs. Guy I bought it from said he went back to stock jets. I put a K&N filter in it now it smells like its running rich. V&H pipe but the rest seems stock. What jets should I put in it at 1100' above sea level and which springs should I use I.E. are stage 3 springs stiffer? Any help is appreciated.
D
Carb Help
Re: Carb Help
Would need some more details like what size jets you already have and if you did the K&N drop in filter or if you switched to pods. It could just be you need to synch the carbs now. But, again, need a little more details.
