exup valve elimination
i am wondering if it is posible to use a exup valve simulator like you can purchase for the r1, im not meaning directly but with a jumper hrness or is there something that alredy exsists to eliminate exup, i have a 92 fzr 1000 btw
Re: exup valve elimination
I'm working on an EXUP Eliminator for the 1k; if you want to be my alpha tester, I might have a prototype to send to you sometime next week.
Sorry - can't help with a '92, unless you're willing to cut the plug off.
I only have the connectors for the '93+. I'm having problems sourcing the round 5-pin (6-1, really) plugs - anyone?
if you send it to me minus the plug i can splice the plug on if you give me the wiring diagram, i am a fairly competent mechanic. I would love to get one to be able to get the full exhaust system without the exup holding me back
Ok - let's see what I come up with!
