Need some help in determining the fork oil capacity and weight - factory spec.
Thanks.
1995 FZR 1000 fork oil capacity and weight
Re: 1995 FZR 1000 fork oil capacity and weight
Per the manual, 470cc of '01' grade suspension oil. Oil height should be 78mm from the top of the tube, fully compressed with the spring out.
