1994 fzr 100 exup. will start up fine and idle perfect but after you drive it for a couple miles the idle goes crazy. one time its idleing at 3k then it drops to 1k then jumps back up to 3k. 100% positive the carbs are clean. just put brand new carb boots on there. the boots helped out alot helped out alot but the idle is still going everywhere. ive let it set there and idle for a few minutes and the idle will just keep going up. it started at 3k and rose all the way to 5k and was still climbing before i shut it off. i do have about 1/8 inch of slack in the throttle cables. any idea's???
fyi. i put on a full yosh exhaust the same time as the carb boots. cleaned the carbs when changing the boots out. the idle problem was like this before i put the new boots on. i thought the reason of the erratic idle was bad boots because they were cracked pretty bad
bad idle
Re: bad idle
sounds likea vacuum leak could be the orings on the manifolds where they go to the heads or the boots or carbs
if i wanted your opinion i'd beat it outa ya
92 fzr 1040, 6 speed, ported and polished head shaved .005",modified 750 clutch basket,factory pro modified center clutch hub,ebc clutch and springs,dynojet stage three jet kit,cut airbox with k&n filter,wrapped header,vance and hines ss2r cut down for weight and backpressure,530 conversion -1 tooth on frt sprocket and 99 yzf r1 frt brake system= oh shit scary fast
82 porsche 911 sc
82 porsche 911 sc
Re: bad idle
seems like something to do with the choke maybe the passage way is partially blocked and when it warms up it swells restricting the flow of air raising your idel
Re: bad idle
I wouldn't say it's a vacuum leak as it wouldn't idle at all (in most cases anyway). I would say that it's probably out of synch carbs along with a mis-adjusted idle set screw. That's just a guess though.
Re: bad idle
alright. i synched the carbs. they were a little off. all four carbs synched a little low below what the manual says. now i can take it up to 10k let off the throttle and it will come down fine. but it will stop at 1500 one time and i will rev it again and the idle will drop down to 300 and die??? air fuel mixture screw is 1/4 turn out. i am about 400ft above seal level, so i will go take it to about 1 3/4 to 2 turns out and see what happens
Re: bad idle
i have my idle air mixture screws at 3 turns out and mine idles at roughly 1250
Re: bad idle
now you have obviously sprayed any suspect areas down iwht carb cleaner to see if idle would change right? that would be the best way to determin if its a leak somewhere
Re: bad idle
sweekster got it...carbs were out of synch and idle air mixture screws were out of whack. she is perfect now. thank you all for your help
- kilika2
- 1000+ Posts
Re: bad idle
That's a running trend. Glad you got your bike running again.coreo19 wrote:sweekster got it
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
