noise
noise
i recently picked up a 91 fzr 1000 with 30 thousand miles on it and its making a ratiling noise at idle . now i have noticed when i start the bike it makes the same noise as it cranks over and some times a loud clunk that stops the starter . other than that it runs great. so my question is could it b the starter clutch i think is what its called? i have a haynes manuel and dont really know what to look for... thanks
Re: noise
o yea i was told its an exup model witch it says on botom fairing but it also says genisis on rear too
Re: noise
The rattle is probably the exup valve in the header (unless you have non stock headers). A good "grease up" of it's moving parts will cure that.
Re: noise
ok thanks i figured thats what the rattle was .will puting a diffrent header (one with out exup )will that change the power band any or need rejeting? thanks
Re: noise
The motor is engineered to utilize the exup valve. So yes, changing the header WILL change the powerband. It'll have almost no power until 4000 rpm. I suggest just servicing the valve (there's an acces panel on the left of the header. you might see 2 cables going to it) with some grease and you'll be good.wheily wrote:ok thanks i figured thats what the rattle was .will puting a diffrent header (one with out exup )will that change the power band any or need rejeting? thanks
Re: noise
thanks ...that exsplains why my parts bike has no power some one took it out and welded a plug over the holes good thing i didnt swap headers..
