Knocking?
josbourn1
Knocking?
Post by josbourn1 »
ruh roh raggy, i rebuild carbs, runs fine, i replace plugs and drive to work, now it knocks!!! what gives. anyone know where i can get a cheap engine? can i use an R1 motor?
1988 FZR 1000 (Basketcase)
mrfreeze5
Level 8.0
Level 8.0
Re: Knocking?
Post by mrfreeze5 »
josbourn1 wrote:ruh roh raggy, i rebuild carbs, runs fine, i replace plugs and drive to work, now it knocks!!! what gives. anyone know where i can get a cheap engine? can i use an R1 motor?
If it ran fine before you rebuilt the carbs and now it doesnt, did you think maybe something in the carbs might be off before you go swapping engines? Have you synched the carbs? did you rejet?
josbourn1
Re: Knocking?
Post by josbourn1 »
no, it ran fine after carbs but not after replacing the plugs.
sweekster
Re: Knocking?
Post by sweekster »
You should double check those plugs....
josbourn1
Re: Knocking?
Post by josbourn1 »
got louder after riding today, very hard restart after running and getting hot.
PIMPMYFZR
Re: Knocking?
Post by PIMPMYFZR »
R1 engine would prob need all the wiring and ecu n such , maybe a yzf1000 engine would be easier if ya could find one . But you check if ya got enoug oil in it <which im sure you prob did ..
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
chefen2006
Level 3.5
Level 3.5
Re: Knocking?
Post by chefen2006 »
A R1 engine is very diferent to an FZR lump. I think it would be very difficould to make it fit. The engine from a Thunderace YZF1000 is almost idintical to the FZR-one,but I think that the cylinders are at a different angel to the FZR. The mounting point at the cylinder head may not be the same? Also the carbs of the Thunderace has the throtle posision sensors,so if you want to use the carbs you would have to use the CPU of the doner bike,or keep the carps of the FZR.
But before you do anything drastic,make sure that you really need a new engine. :cheers:
tampaFZR600
Level 4.0
Level 4.0
Re: Knocking?
Post by tampaFZR600 »
ummm did you put in the right plugs!?
josbourn1
Re: Knocking?
Post by josbourn1 »
anyone have the NGK plug number?
reelrazor
Wrench
Wrench
Re: Knocking?
Post by reelrazor »
josbourn1 wrote:anyone have the NGK plug number?
For an FZR1000? '87 thru '96 it is listed as a DP8EA-9 (iridium plug # DPR8EIX-9)
(autolite equivalent = #4164)
