head lights
Posted: Fri Aug 28, 2009 9:58 pm
by Soaringman
Any ideas why my head lights don't work.
all other lights work, they stopped working after I had a trickle charger pluged in for a couple of days.
all fuses are good.
Re: head lights
Posted: Fri Aug 28, 2009 10:05 pm
by shredex
bulbs?
Re: head lights
Posted: Fri Aug 28, 2009 10:13 pm
It could be the bulbs or the wire in in the switch itself. The older ones tend to have a wire come loose because of a weak solder joint. I'd open the switch and check it out along with the fuses.
Re: head lights
Posted: Wed Sep 02, 2009 10:52 pm
by Soaringman
Thanks for replies, When the bike runs all lights are on, so there is no on off switch.
wouldn't think it's the bulbs as both went off at the same time.
but I will check, how do the bulbs come out ? Abel to pull the power off but do I need to turn the bulb ?
Re: head lights
Posted: Wed Sep 02, 2009 10:55 pm
by KASH
put a test light on the socket and see if your getting power
Re: head lights
Posted: Tue Sep 08, 2009 12:52 am
by Soaringman
Ok, I got power at the fuse but no power at the bulb.
I'm thinking busted wire.....?
Re: head lights
Posted: Tue Sep 08, 2009 2:13 am
by delvryboy
Check the wire directly behind the connector, use a pin in the wire. Chances are its the connector.
