Any ideas why my head lights don't work.
all other lights work, they stopped working after I had a trickle charger pluged in for a couple of days.
all fuses are good.
Thanks
head lights
- shredex
Re: head lights
bulbs?
Re: head lights
It could be the bulbs or the wire in in the switch itself. The older ones tend to have a wire come loose because of a weak solder joint. I'd open the switch and check it out along with the fuses.
- Soaringman
Re: head lights
Thanks for replies, When the bike runs all lights are on, so there is no on off switch.
wouldn't think it's the bulbs as both went off at the same time.
but I will check, how do the bulbs come out ? Abel to pull the power off but do I need to turn the bulb ?
Thanks
Thanks
Re: head lights
put a test light on the socket and see if your getting power
- Soaringman
Re: head lights
Ok, I got power at the fuse but no power at the bulb.
I'm thinking busted wire.....?
Re: head lights
Check the wire directly behind the connector, use a pin in the wire. Chances are its the connector.
'92 FZR600
Lots of Powder
Lots of Powder
