Tail swap
Re: Tail swap
Saw one on a stretched 94, tail didnt look too bad in the pics, but the bike looked like poo! i cant say it wouldnt be impossible! do it, and post pics! haha
I did that.
Re: Tail swap
josbourn1 wrote:ok, i see a ton about R6 swaps on FZR600's, what about the FZR1000? I want a new tail for my 87.
Try an R1 tail, either photoshop it or get a whiz kid pal to do it :-}
Re: Tail swap
It just so happens the r6 tail is a common thing for the 600. The 750's and 1000 are actually easier for tail swaps since the subframe bolts on. The 600s don't. If you are a good fabricator just make a new subframe (or have one made) and then drop on the tail you like the best. I doubt you'll get any kind of a "straight" answer because that is a customization question and each person you ask will say something different.
- Fizzinatorr
- Level 6.5
Re: Tail swap
and hey look Fizzinatorr has a complete set of R1 plastics for sale!
what a coincidence...
pm me if you want a good deal
- ShogunTX
- Level 4.5
Re: Tail swap
Not to revive an old thread but it has been done mshap's Jello
Saw it a few years back
Re: Tail swap
The Lady spent an awful load of money but quite wisely it seems I wish she had put details of the FI system on the page tho.ShogunTX wrote:Not to revive an old thread but it has been done mshap's Jello
Re: Tail swap
George on the exup worldwide page theres a decent wright up of her when she was going through the FI system. Actually a decent amount of people have convert their Exup's to FI as well. Seems like a popular mod on that forum. Just have to have some change to drop(between 1-2 grand) but still for the price of Flatsides I'd go with FI. just my 2 Cents.
Jello is beautiful <3
1992 FZR 1000
- Level 4.0
Re: Tail swap
Why would it cost between 1-2G to convert to FI?
$400 for microsquirt
$30-50 Throttle bodies
$50 to have throttle bodies spaced out differently if needed
$100 on different carb holders/adapter plates
$20 hi pressure fuel pump
$150 misc sensors
That's about it. I think I am going to fuel inject my bike this winter. I already got the throttle bodies for $1 off ebay and just paid shipping.
$150 misc sensors
Re: Tail swap
FS,Freestyle72 wrote:Why would it cost between 1-2G to convert to FI?
$150 misc sensors
it depends on how your luck runs on Ebay. I have kept my mods so cheap because I have patients and I plan for the long term.
other want it done yesterday
Re: Tail swap
I'm with Geo, took me 6 months to collect (off eBay) parts for my R6 tail conversion, YZF tank with fuel cap £48, 5EB tail £8, riders seat £13, pillion seat £18, seat catch with cable £9.99, Renntec grab rail £9.88, all included shipping. Just gota be patient, i could easily have paid more than double that.
Re: Tail swap
and what about if you want some sort of data logger? or how about tuning? or time on the dyno to just get things peachy? Also you can't use megaquirt with the stock cdi/ignitor I believe. Thats why it helps having a V&H powerpack or an MSD MC-3 which will run you 500 new or if you're lucky enough to get a powerpack cheap.There was a guy on worldwide from germany selling a full turn key set up for 2 grand. Everything you needed to just plug in and go. down to the tuning software. I know you can piece things together cheaply. and Usually something like this is done over time but its not cheap is what im getting at...nothing is cheap with these things but its an addiction and i love it..
1992 FZR 1000
Re: Tail swap
I seem to remember mentioning mega Jolt as the Computerisation of the ignition...............
But you are right testing without an osciloscope would be a bit expensive and yes Dyno runs could get quite pricy
Re: Tail swap
If you are going 'fuel only', you most certainly can; just use the 'coil negative' arrangement off one coil or the other. If you are going 'fuel and spark' ... well, you're using the MegaSquirt as the ignitor anyway, aren't you?Also you can't use megaquirt with the stock cdi/ignitor I believe.
The issue is not the TCI / Ignitor, but rather the timing pickup - the MS as currently configured doesn't know how to read a 'long-tooth' rotor. There is a project under way right now to develop a system to read the stock FZR wheel using the stock Variable Reluctor pickup; this would allow the MS to read and drive the spark on its own. This is garnering a bit of notice as the '3 short + 1 long tooth' wheel was used on many bikes over the years.
By adding a cam sensor (which I'll be doing for sequential injection anyway) and using a hall sensor as your crank pickup, the wheel becomes a 4-0/1 - quite readable by the MS system.
(caveat - for the fuel & spark system, I'm talking an MS2 running Extra code)
