Squeaky rear shock after shorter dogbones installed
Posted: Sun Jun 14, 2009 4:38 pm
by ofloinn3
Hello everyone, I recently replaced my stock dogbones with shorter ones to raise the tail on my '94. The tail was stiff as hell for the first couple of days riding. It has loosened up and feels good now. But, I now have a squeaking coming from it that I never had before. It's hard to pin point whether it's coming from the mounting bolts or the spring itself.
Any idea's on how to fix? I have never removed and reinstalled a shock before. Do I unbolt it while on the rear stand from top to bottom or does it matter? If I need to replace it ...is there a bolt on upgrade from a new model I can use?
I can hear the squeak while riding and it's driving me crazy. Help before I crack!! Thanks!!!
Re: Squeaky rear shock after shorter dogbones installed
Posted: Sun Jun 14, 2009 5:27 pm
by megaloxana
Try applying some grease in the bolt holes of the dog bones.
Posted: Sun Jun 14, 2009 5:45 pm
by Huckleberry
Bolt on an 05 r6 shock (guys correct me if my year is wrong) Its the one with the two adjustment screws and a red spring.
Posted: Sun Jun 14, 2009 5:58 pm
by tkclow
sounds like the right year. check with reelrazor, he may still have one already modded to fit. i got mine from him. Awesome to deal with and very helpful.
Posted: Sun Jun 14, 2009 7:10 pm
He rides a 94 1000..R6 shock don't work. Changing the angle creates a new stress point. Lube all the bushings and spacers (along with the holes of dog bones like Mega suggested) with a good lube or grease and you should be good to go.
Posted: Sun Jun 14, 2009 7:22 pm
by tkclow
sweekster wrote:He rides a 94 1000
AHH, Did not know that. Sorry
Posted: Sun Jun 14, 2009 8:48 pm
by Huckleberry
doh , man im sorry my bad
Posted: Mon Jun 15, 2009 11:22 am
by the_finch
What sweeks said on lubing the whole thing.
I took off the plastics on my tail and used a pair of ratchet straps to lift the tail, unbolted everything, popped all the inserts and bushings out of all of the suspension pivots, packed them with Bel-Ray waterproof bearing grease, and put it all back together.
Mine had the squeaky/binding suspension and it turned out the Previous Owner had never lubed the suspension. Two of the bearings had rusted solid and eaten up the bushing, and I had to replace them. Now the suspension works like it should.
Posted: Tue Jun 16, 2009 3:57 pm
by ofloinn3
Thanks for all the suggestions guys. There calling for rain the rest of the week here in Baltimore, so I'll get on it as soon as I have a dry place to work. Hopefully greasing it up works. Otherwise, I'll have to change my name to Sweaks.
Posted: Tue Jun 16, 2009 8:26 pm
by megaloxana
ofloinn3...you might be interested in a ride we're planning. Im just past the PA/MD line so you could stop up and meet up with me then we'll head out if you're interested.
Here's the link
