clutch help
Posted: Sun Mar 15, 2009 10:19 am
by josbourn1
how much travel should there be in the clutch slave cylinder? im only getting about 1/8".
Re: clutch help
Posted: Sun Mar 15, 2009 10:25 am
Welcome. Slave cylinder? The FZR600 uses a clutch cable and the FZR1000 uses a hydraulic clutch..which bike are you referring to?
Re: clutch help
Posted: Sun Mar 15, 2009 10:27 am
by josbourn1
FZR1000, hydraulic clutch cylinder.
Re: clutch help
Posted: Sun Mar 15, 2009 11:17 am
My manual doesn't actually say how much travel it should have but 1/8th is not very much. You've tried bleeding it out? Does the lever have feel to it? Or can you pull it in fairly easy? Might be time for a rebuild of the cylinders (master and/or slave).
Re: clutch help
Posted: Sun Mar 15, 2009 12:40 pm
by 95FZR600
Sounds like the slave is going out or good cleaning is needed.
Re: clutch help
Posted: Sun Mar 15, 2009 6:24 pm
by josbourn1
theres between 1/8-1/4 travel but no real force. the handle pulls solid, feels like it should. i have bled it several times, no leaks.
thanks for the help.
Re: clutch help
Posted: Sun Mar 15, 2009 6:37 pm
by 95FZR600
Good to hear!
Re: clutch help
Posted: Tue Mar 17, 2009 10:27 am
by josbourn1
OMG!!! How long should it really take to bleed a clutch???!!! spent 1 1/2 hrs already and there is still small bubbles!
Re: clutch help
Posted: Tue Mar 17, 2009 10:36 am
LOL..The bleeding can take a good while. I use a MityVac vacuum pump. Took me probably 10 minutes the last time I bled my clutch.
Re: clutch help
Posted: Tue Mar 17, 2009 10:52 am
by haunter
josbourn1 wrote:OMG!!! How long should it really take to bleed a clutch???!!! spent 1 1/2 hrs already and there is still small bubbles!
that the bike and let it get warm, rev it some, turn it off and let it sit for a few hours, or even a day, you will get ALOT of air out that way, as the vibrations will help th eair filter to the ends of the lines.
you could also have a bad vac or bleeder line
Re: clutch help
Posted: Fri Mar 27, 2009 10:17 pm
by josbourn1
Update- I have since repalced master and slave, still not releasing clutch. the clutch was recently replaced by a shop, could they have done something wrong? they drove it around after repair. im just at a total loss. help me!!!!!!!!
Re: clutch help
Posted: Fri Mar 27, 2009 11:53 pm
by PIMPMYFZR
josbourn1 wrote:Update- I have since repalced master and slave, still not releasing clutch. the clutch was recently replaced by a shop, could they have done something wrong? they drove it around after repair. im just at a total loss. help me!!!!!!!!
i would take it back to them first , and dont tell them u messed with it just be like i got my sh*t fixed here and still not working right ...
Re: clutch help
Posted: Wed Apr 01, 2009 8:24 pm
by josbourn1
UPDATE...
CLUTCH DISKS WERE STUCK/FROZEN! ITS FIXED NOW. Thanks for the help.
Re: clutch help
Posted: Wed Apr 01, 2009 11:26 pm
by mossy1200
Sounds like the fibres were not soaked in oil prior to fitting.If the shop did them for you hope they are not charging you for refix.
