Clutch bite point
Schmo9
100+ Posts
100+ Posts
Clutch bite point
Post by Schmo9 »
Anybody else have a high bite point on their clutch ( clutch lever right out before clutch engages).. there is no adjustment on the 87 bike. Changed clutch plates but still high?
Cheers
In the garage:
2012 VFR1200X Silver
1997 ZX7R P2 black
1992 TDM850 Mk1 army green
1988 FZR 1000 2RG White and red
buzzawak
Re: Clutch bite point
Post by buzzawak »
hydraulic clutch, no adjustment
Stig
Level 3.5
Level 3.5
Post by Stig »
I fitted the adjustable lever off the 750 so the bite point felt more natural
http://www.exup1000.co.uk
Schmo9
100+ Posts
100+ Posts
Post by Schmo9 »
So the clutch bite point is high on this bike by default? Master cylinder to slave cylinder ratios incorrect? Will look at FZ lever if all else fails.
In the garage:
1997 ZX7R P2 black
Schmo9
100+ Posts
100+ Posts
Post by Schmo9 »
Ok having thought about this problem more I will ask about it a different way..
What would need to change or fail in the clutch hydraulic system for the bite point to move to the lever almost fully out position. I don't believe the bike was designed this way or its by default.
I believe the clutch master cylinder I have is standard as it came with the bike although I will check the bore size (I believe 5/8 is the standard). And the slave cylinder is standard also
Like I say I will check M/C against factory manual as it may very well be the wrong one... maybe 5/8 bore is wrong and I should be looking for 14mm or even 1/2". But, if the M/C is correct and the S/C is correct, what else could possibly be wrong??
In the garage:
1997 ZX7R P2 black
Schmo9
100+ Posts
100+ Posts
Post by Schmo9 »
Solved
In the garage:
1997 ZX7R P2 black
