I got it for £300 from a mate of my brother, after i'd mentioned i was after a 1000 motor to put in my FZX750-R1 (but thats another story
The lad said it wasn't running right and he'd had a look but wasn't sure what the problem was. I got it to my workshop and stuck it out back under a cover, where it stayed for nearly 2 years! I was just too busy with work and home life to even think about ripping it appart. Until one day i thought sod it i'll get it out and just see if i can get it fired up.
So started taking it appart and hoovered all the spider webs and snail poo off of it
Carbs were cleaner than i expected
As for the plugs.........
1 was different to the other 3, 1 had 2 washers, and 1 had no washer!
Also coil leads 1 and 2 were on the wrong way round
Anyway, done all that, got a starter pack and a can of fuel and hit the button.........
https://www.youtube.com/watch?v=Kcm8DzAmtrE
https://www.youtube.com/watch?v=18ij9dkDwIk
So with the motor running i started thinking about maybe re building the bike instead of just using the engine. I'd always loved the look of the FZR, especially the white with red speed blocks style. The thing is, i've always been one for modifying the hell out of things, and this one was in a right state. Would take a lot of work, time and money, but I love working on bikes so i figured i'd have a go at it. I started thinking about putting upside down forks on it and maybe putting a different back end on it but in all my searching on the net, i kept coming back to this photo..........
I thought sod it, i'll do a full resto job on it, back to showroom condition
So started the strip down to see what it needed.
New brake pedal,
Wiring loom had been cut to shit,
Did you notice the wood screw holding the coil bracket on ^^^^
This bit of speaker wire was running from front to back of the bike
Loads of broken bits all over it
Tank was rusted through at the bottom
Rad had been 'repaired'
Water system has shit itself
Exhaust can was rubbing on the swingarm
Basically the more i looked, the more i found. But i love a challenge. And love making/fixing things
Thought i'd start with something easy, so made the missing fairing bracket for the right hand side, based on the one on the left side, and pics from the net.
First turned down a bit of solid bar,
Then made the base from a bit of angle
Shaped it a bit, et voila
Next up, the foot peg hangers,
Bit of Ali plate shaped and tacked on
Welded and cleaned up
And a few holes
