I own an fzr 1000 ru 1993 model. The bike has only done 14000 miles as it has been in storage over half it`s life. The problem i`m having is this. When i rev the bike (standing next to it) the revs go up and down as normal and returns to idle. However when i get on the bike and ride, when pulling the clutch in after accelerating the revs are staying up, not good for the clutch. Having ridden the bike for 10 minutes or so, when i feel the downpipes number 1 & 4 are quite a bit cooler than 2 & 3. I can touch 1 & 4 but 2& 3 burn.
I have stripped and cleaned the carbs, countless times. The emulsion tubes are new and i replaced two of the diaphragms, so all four are perfect. I have set the float heights to 14mm with a cut out credit card and set the mixture screws 3 turns out as a starting point. I have replaced the coils with 2.2 ohm dyna coils and taylor leads. The original silencer has been replaced with an sp engineering end can and I have checked the jet sizes are correct in all four carbs (these are standard jets).
Apart from the revs not coming down after giving the bike throttle there is still an immense amount of power and cannot fault the acceleration. Should i have checked the fuel height as specified in the haynes manual? Are the jets right for the slip on i have put on? The exup valve is still in place and is fully functional. What could be causing number 1 & 4 pipes to be cooler than 2 & 3. Help and advice would be greatly appreciated. Thanks
