Need some help
Posted: Sun Mar 06, 2016 6:04 pm
by paultstolz
Well just bought an 90 fzr1000 it's all torn apart n it needs a starter clutch would someone guide me through how to get to it and either fix or replace it thanks for your time
Sent from my XT1585 using Tapatalk
Re: Need some help
Posted: Mon Mar 07, 2016 6:47 am
by Kevadlilleke
Frame and fairings seem to be '89-'90, but engine seems to be '91+ (judging only based on oil filter and its base). Seems quite badly messed up, not just torn apart.
Re: Need some help
Posted: Mon Mar 07, 2016 10:18 am
by paultstolz
Thanks for your help
Re: Need some help
Posted: Mon Mar 07, 2016 2:53 pm
by Schmo9
Never done a starter clutch, it's a big job but your engine is on bench so half job done already...found this...
http://www.yamaha-forum.net/forum/82-fz ... 376?page=1
Also yambits does repair kits
Re: Need some help
Posted: Tue Mar 08, 2016 12:36 pm
by kolederacer
You have to split the case. I probably have a spare one.
Re: Need some help
Posted: Tue Mar 08, 2016 4:59 pm
by paultstolz
Ok ty I'm gon check eBay once I get it tore apart n narrowed down I seen rebuild kits on eBay. Anyone have any luck with those?
Re: Need some help
Posted: Wed Mar 09, 2016 4:46 am
by Kevadlilleke
Get parts catalogs from here:
http://www.exup1000.co.uk/tech/fzr1000r/index.html
http://www.exup1000.co.uk/tech/fzr1000ru/index.html
Because of swapped engine, you probably need both...
Check if any of the critical (more expensive) bits are missing.
