Genesis1000 build
Posted: Fri Jan 22, 2016 12:04 pm
by Silverfox57
Hi I thought I would post some pictures up off my new project see what you think
And it only has 13k on the clock
Re: Fzr 1000 build
Posted: Fri Jan 22, 2016 12:52 pm
by willandrip
Plenty of work for you there.
Have you seen Schmo9's build thread ?
viewtopic.php?f=10&t=12620
Re: Fzr 1000 build
Posted: Sun Jan 24, 2016 10:06 am
by Silverfox57
Yes read it with interest, he has done a good job so far
Re: Fzr 1000 build
Posted: Sun Jan 24, 2016 10:19 am
by Schmo9
Silverfox57 wrote:Yes read it with interest, he has done a good job so far
Cheers... body work going away soon for full respray... hopefully be ready for spring.
Re: Fzr 1000 build
Posted: Mon Jan 25, 2016 7:28 pm
by kolederacer
Obviously you have a lot of work ahead of you.
But looks like your plastics are pretty good.
You already have the newer suspension all the way around.
I bought a complete bolt kit for the engine from ebay i believe and the one i got is good quality and would fix all your rusted bolts.
Your side cover is also off a newer bike on the engine but thats no big deal.
Also you already have different brakes on the front. I am not sure what they are off of exactly.
I would just clean the frame up and then clean the engine probably vapor or soda blast then repaint it and it could be a really nice bike.
If you decide not to re build it with the stock fairing let me know i would be happy to buy some of that stuff off you.
Also if you need any parts for 87-88 i have most of them in duplicate.
Good luck!
-kole
Re: Fzr 1000 build
Posted: Tue Jan 26, 2016 1:29 pm
by Silverfox57
Hi and thanks what bolt set was it ,I will need a top fairing as it's lost one of the small piece where the mirror fits
Re: Genesis1000 build
Posted: Tue Jan 26, 2016 2:59 pm
by kolederacer
Well lets see.
This is the only upper fairing set i can find new. They do require some work to finish them but better than nothing.
http://www.perfect-fairings.com/en/prod ... irings_218
Here is the bolt kit i bought. i know its not for a genesis but i did not have have any real problems. They were even labled for the areas they go in. They are not the best quality i have ever seen but far from the worst also.
http://www.ebay.com/itm/YAMAHA-FZR1000- ... 4A&vxp=mtr
Last feel free to ask any question i have been building these for a while now, Also if you are interested in any improvements like yzf750 cams or yzf750 carbs i have some of those i would sell.
Posted: Tue Jan 26, 2016 3:00 pm
by kolederacer
Posted: Tue Jan 26, 2016 3:24 pm
by kolederacer
Here is my engine when i finished it. It looked about like yours originally.
Posted: Wed Jan 27, 2016 1:04 pm
by Silverfox57
Well I was out in the garage today , started the bike up dosent sound to bad it has a rattle sounds like it's behind the autonator so will have to look at that,one of the carbs
Needs sorting ,when it's running it's like running on 3 but if I but my finger over the carb at the top it runs good,
So this is what I did today
On the ramp
Now the fun begins
Posted: Thu Feb 04, 2016 12:34 pm
by Silverfox57
Hi all just a couple of pictures of the engine before painting
Question should I use a etch primer first
Posted: Thu Feb 04, 2016 1:01 pm
by kolederacer
Ummm..
I did. Seems to make it last longer. along with clear.
Posted: Thu Feb 04, 2016 2:19 pm
by Silverfox57
But will the heat not make it peal of
Posted: Fri Feb 05, 2016 12:02 pm
by Silverfox57
Ok so I had a chance to get in to the garage today and this is what I did
Posted: Fri Feb 05, 2016 12:07 pm
by willandrip
Silverfox57 wrote:Well I was out in the garage today , started the bike up dosent sound to bad it has a rattle sounds like it's behind the autonator so will have to look at that,one of the carbs
Now the fun begins
You may find that the noise goes away completely if and when you get it running again and balance the carbs.
Rough running engines develop all sorts of rattles, knocks and bangs.
