Tethered kill switch type?
coops
Level 1.5
Level 1.5
Post by coops »
Going to enter Burt Munro street race in November and must have tethered kill switch for this.
What type do I need? I think there is basically two types, normally open or closed. And do I just tap into the right handlebar kill switch? (I still have one)FZR1000 89
Got another race bike so I can run two classes. Costs the same at track but will get twice as much racing in. Heres a pic.
Re: Tethered kill switch type?
If the "Normal" state is with the tether pulled, then you'd want the NO variant if you're tapping into the kill switch. Make sure it's rated for 10+ amps.
coops
Level 1.5
Level 1.5
Post by coops »
DonTZ125 wrote:If the "Normal" state is with the tether pulled, then you'd want the NO variant if you're tapping into the kill switch. Make sure it's rated for 10+ amps.
Thanks Don. That's a good question. What is "Normal"? I would expect normal is with the tether not pulled cos things aren't normal when you pull the thing lol
If that is the case, I will need N closed.
I will look into it, Cheers
Hi, Coops.
For any spring-loaded switch, "normal" is in the relaxed position, with the spring extended. A relay is in the normal position when it is unpowered; the tether switch would be in the normal position when the tether wedge isn't forcing it into the 'powered' position.
You want Normally Open.
