Genesis project (Finished)
Schmo9
100+ Posts
100+ Posts
Post by Schmo9 »
Well as promised here are some pics of my new project...a 1988 Genesis. A sorry state but this will be a full resto back to original spec.
I have the fairing but a lot of bits missing.
Pics are of when it arrived at my garage and it's progress so far....will use this thread to track my progress..
Image[/url]
In the garage:
2012 VFR1200X Silver
1997 ZX7R P2 black
1992 TDM850 Mk1 army green
1988 FZR 1000 2RG White and red
willandrip
Level 7.0
Level 7.0
Re: Genesis project
Post by willandrip »
Nosecone will be the hardest to source.......start searching now !
See by your pics you are also on the Carpe forum.
Good pics btw.
Schmo9
100+ Posts
100+ Posts
Re: Genesis project
Post by Schmo9 »
I have the nose cone..It has some damage but nothing that can't be fixed. Yeah im on Carpe how can you tell??
In the garage:
1997 ZX7R P2 black
willandrip
Level 7.0
Level 7.0
Re: Genesis project
The link goes to your photobucket album with the 3VD in military paint.
Schmo9
100+ Posts
100+ Posts
Re: Genesis project
Post by Schmo9 »
Sorry that link wasn't meant to be there...but yeah just finished the TDM...it was red but after years of being stored outside it was pink..lol. military paint real easy to use and drys very quick...
In the garage:
1997 ZX7R P2 black
Schmo9
100+ Posts
100+ Posts
Re: Genesis project
Post by Schmo9 »
Can someone advise the colour code for the white wheels or is it as simple as just powder coating satin white??
Cheers
In the garage:
1997 ZX7R P2 black
kolederacer
100+ Posts
100+ Posts
Re: Genesis project
Post by kolederacer »
I have a lot of parts for genesis so if you can't find something let me know
1974 RD350
2003 Honda RC51
2013 Yamaha YZ450f
Schmo9
100+ Posts
100+ Posts
Re: Genesis project
Post by Schmo9 »
kolederacer wrote:I have a lot of parts for genesis so if you can't find something let me know
Cheers mate....i do need the small inner panel that sits with the air duct on the inside of the RHS panel?
In the garage:
1997 ZX7R P2 black
Schmo9
100+ Posts
100+ Posts
Re: Genesis project
Post by Schmo9 »
Ok since no one knows the colour code for the wheels i'll just go with satin white powder coat....a few more pics of my progress so far
Engine out
Alternator, starter motor, oil pipe, water pump, inlet manifolds and cooling pipes off
Valve clearances checked and all within spec :headbang:
Engine painted next....
In the garage:
1997 ZX7R P2 black
willandrip
Level 7.0
Level 7.0
Re: Genesis project
I cannot help with the wheel colour code.........mine have been painted with rattle cans or 2k .
What prep did you do for engine paint.......?
You will be getting the frame cradles and subframe coated ?
Schmo9
100+ Posts
100+ Posts
Re: Genesis project
Post by Schmo9 »
Degreaser, wirebrush and plenty elbow grease. Basically scraped the 25yrs of crud off, got stuck in with degreaser and toothbrush then wire brushed. Everything that has come off has been on a wire buff and coated in engine paint (spray)....engine block will be hand painted with hi temp enamel engine paint.
I've cleaned up the cradles and sprayed them back to looking new. Frame appears to have been polished in its past...didn't think I would like it but I'm still deciding what to do there...
In the garage:
1997 ZX7R P2 black
willandrip
Level 7.0
Level 7.0
Re: Genesis project
I did the TDM that had been badly overpainted with a hot degrease powerhose then gunwash thinners, wire brushes and finally masked every orifice and hit the hard to reach bits with a jerry rigged blaster and dried block paving sand.
I wanted to just get back to the original patina.
I then gave it a few coats of laquer.
It was lots of work.....yours looks like it was even more so.
The good thing if your repainting is that every scrap of paint does not need removal ,just the loose and any oxidisation and blistering.
It will transform the project.
Once the frame is polished it can be got back to somewhere near the original finish (it was anodised/coated)
by use of scotch pads worked in one direction.....this will also be very time consuming.
Polished frame with the polished clutch cover looks good IMO.
A cheap compressor and some add ons (a small touch up gun is about £15) are your friends on these jobs......painting the engine becomes childs play and the finish is far superior/durable to brush finish.
Schmo9
100+ Posts
100+ Posts
Re: Genesis project
Post by Schmo9 »
Finally got me an engine stand. Three of the exhaust studs were seized solid so this made drilling them out a piece of cake
New studs in and wee clean and paint..
In the garage:
1997 ZX7R P2 black
Schmo9
100+ Posts
100+ Posts
Re: Genesis project
Post by Schmo9 »
Just got me an original 4 into 1 exhaust system for the rebuild...almost brand new :))
In the garage:
1997 ZX7R P2 black
Schmo9
100+ Posts
100+ Posts
Re: Genesis project
Post by Schmo9 »
Howzat . ..
before..
After..Image
In the garage:
1997 ZX7R P2 black
