Vinyl wrapped frame
Posted: Sun Mar 15, 2015 11:35 am
by 78cobra
So since I decided to overhaul my bike this winter. I had decided I want to make the bike look 'fresh' as well. My choices to the frame were, keep stock, polish, paint (or vinyl) black, vinyl chrome, or gold vinyl chrome. My main goal was being able to go back to stock. And make look nice.
I decided on gold chrome vinyl. Mainly because most guys who freshen their frames look is to polish it. it looks nice but on the 94 1000 I personally don't like the look of it polished. And polishing the part of the frame that the sub frame attaches to just makes things odd & difficult.
Re: Vinyl wrapped frame
Posted: Sun Mar 15, 2015 12:02 pm
by 78cobra
This is the first time wrapping anything and was deffinetly a challenge. I used a 5ftx5ft sheet I would recommend going with double that for your first time so you can redo any mess ups instead of having to make them work. Though 5x5 is enough to do everything.
- Before I started the wrap
Now, this is the first time I have ever used vinyl, none the less harder to use chrome vinyl.
Posted: Sun Mar 15, 2015 12:14 pm
by 78cobra
I was originally going to do the rims too. But I think that will be too much gold chrome. Aswell as it may be more of a pain in the neck to do than I'd like to. Plus I'm bad at cleaning my rims, that tend to get soo dirty and the black hides that nicely. Though I may do the lip.
As from what I know, we'll could find on google. No one else has gold wrapped the frame of a motorcycle. My only concern is issues from the frame getting so warm. I may be running an aftermarket fan actuator to help keep Temps down. But an easily removable one, since wrap is not permanent.
I plan on doing the lower half of the front forks, possibly the rearsets, and rotors, but not sure.
Posted: Tue Mar 17, 2015 1:53 am
by AussieFZR
Look really good mate. I be interested to see how it holds up over time with engine heat. Was it hard to do?
Posted: Wed Mar 18, 2015 2:13 am
by coops
Looks great.
Posted: Tue Mar 24, 2015 11:02 am
by kolederacer
Thats not a bad idea. I just sent one of my frames to powder coat. How much did it cost?
Posted: Thu Mar 26, 2015 10:35 am
by 78cobra
For 5ft x 5ft of gold chime vvivid it cost me about $38 U.S. but you will also need gloves, non scratching and non static. Though I used a set of gloves from the dollar tree or harbor freight that were soft. You will also need a felt squeegee I recomentadion at least 2 3" or 4" ones about $6-10 from amazon. Then lastly you need a heat gun and I would recomentadion one that doesn't have a trigger, one that can just stay on. I had one already it was from harbor freight it cost about $40. So about $100 total.
The one thing I would recommend is also buying adhesive promoter in brush on type. That's about 20 -30 plus another 5 for tin brushes from harbor freight. I didn't use any because I have no idea what residue or effects it would have on the frames protective coating, after vinyl is removed. But people do use it on car paint so I don't think it could be that bad.
As for heat of the frame. Well I have a lamp I put a decent size square on. The lamp gets so hot it will leave a nice burn just touching it. The vinyl has actually settled on nicer than when I just plopped it on as well as when it's hot I could squeeze out some bubbles. Be careful if you do it it can scratch so let it cool a little. Aswell as it shows no signs of wanting to peal from the heat. It just seems to want to stick even more.
