Here is a quick Photo
So i can run a 17" rear wheel.nikko wrote:Hello there. I am curious why you decided to swap the rear swingarm? Looking forward to your build. I have an 87 1000. looks rough but running. Not sure which direction to take it.
What all did you have to change for the r1 calipers and what year did you use?coops wrote:I personally think you should leave the carbs and intake system alone. (maybe just a freshen up in the carbs)
You will spend a whole lot ov moneys on new flatslides for very little gain and in some cases loss. Unless you are prepared to do heaps of work tuning the carbs.
New can is good for loosing weight only. Maybe the cam is a good idea but I don't know myself.
The three best improvements I did to mine was,R1 calipers with new braided lines, emulators and stiffer springs on front and ohlins shock at rear. (in that order).
If you want too chase big power you probably should have started with a different bike (money wise)
Have fun.
Too much beer and things stuffed my memory. My calipers were 2006 R6 I think but many years fit (theyre all the same) 2002 -2006 R1 or R6 all work?? Search WIKI or someone else will pipe up for exact information. Easy, bolt straight on. Most difficult thing is bleeding the brakes. I had a right prick of a time getting them right. Took me months!kolederacer wrote:What all did you have to change for the r1 calipers and what year did you use?coops wrote:I personally think you should leave the carbs and intake system alone. (maybe just a freshen up in the carbs)
Have fun.
I did find some bad news when i went into the engine. The motor had a nasty tick and turns out one of the crank teeth is chipped pretty bad. I did get lucky and find a low miles crank in great condition and a set of the R1029 pistons.
I also spoke with kurt at Jordan engineering and he is extremely knowledge about these bikes and engines. He said the best engine upgrades are
- exup pistons and rods. The center valve recess does have to be open up by .005 because of the change in valve angle. It will also run 13:1 compression.
- YZF750 cams - Longer duration helps get fuel in for the larger bore and compression.
- Pod filters believe it or not with dyno 3 jet kit. He also recommended stock carbs.
Nothing on the shock its self other then finding a place for the reservoir.nikko wrote:Thanks koledracer for the picture updates. The rear swingarm looks really good there. Were there any shock mods needed for the swap?
Haha understand that. Love the paint on yours btw.coops wrote: Too much beer and things stuffed my memory. My calipers were 2006 R6 I think but many years fit (theyre all the same) 2002 -2006 R1 or R6 all work?? Search WIKI or someone else will pipe up for exact information. Easy, bolt straight on. Most difficult thing is bleeding the brakes. I had a right prick of a time getting them right. Took me months!
Also, Be very weary of 13:1 comp ratio. I don't actually know for sure, but just do your research, cos I remember reading about continuously blowing head gaskets with the high comp. If your gonna go down that road apparently the clutches are weak so you need a billet clutch more $$$ And the 2nd gear problem, they all have it.
Mine did. That's why I kept mine stock.
