basket case,new c local yam shop killin me !
big special
new carb rebuild kits float set new petcock used sending unit tank cleaned out used clip on new ignition( stig was right on with ignition problem) ignition wire plug in block at the triple tree area had got hot the 2 spade terminals in the plastic joined together in the hot plastic resulting in the ignition not turning the bike off, new ignition installed. she fired right up and idled at 1200 rpm ! NOW MY PROBLEM fuel rail seals are leaking YAM SHOP WANTS 50.00 US for 6 orings,does anyone know a better source? OR DO I JUST NEED TO PAY THE MAN! THANKS PREVIOUS OWNER WIRED RADIATOR FAN TO INSTANT ON WITH IGNITION ? FAN SWITCH BAD MAYBE?
Re: basket case,new c local yam shop killin me !
Theres a supplier of mikini carb spares not far from me. They're closed until Tuesday tho' but i dont mind giving them a call to chek on prices. its no hardship to send them over the pond if they're not willing to post overseas
I'
I'
big special
Re: basket case, local yam shop killin me !
thanks Mr stig i went on and payed the yam dealer he cut 10 off got them fourty USD I havent forgot about the dogbones thanks
