New here...carb help?
Posted: Sun Jul 06, 2014 12:00 pm
Hi everyone
Brand new here, and new to the fzr. Was a 91 gixxer 11 guy, had kid, sold it. Bought a 98 vfr, had kid, sold it. Kids are bigger, and found a 91 fzr1000. Single owner, never in rain, never down, garage kept, absolutely showroom. Bone stock save for a V&H can, and a K&N insert. Bike was garage kept, but not ridden since 02. Here's the issue. Rode it back home, about 80k. Carbs were clearly an issue. Was running lean and flat at WOT. took it in for service at the Yamaha dealer, as I've got to buddies there Carbs cleaned, new fuel pump, apparently guy says stuck ring? Ran ring free thru fuel. Got bike back 2 days ago, expecting it to be better. It's worse. Starts fine, idle hangs at 2k after warming, but....anything past 1/4 throttle, and I may as well be sitting on a ysr50. Sounds like everything I've read leads to tubes, but worn tubes make you rich? 25xxxK on the bike. Sat for a dozen years tho. Exup servo is working. It's definitely running lean now. I can feel the heat. Vacuum leak, issue at the slides?
Had the bike for a month. Have ridden it for an hour
. Maybe my living room is the best place for it
