splitting cases
splitting cases
Does the clutch basket have to be removed?
Re: splitting cases
Il answer that myself.......... Yes it does. The bearing retainer behind the clutch has to be removed before splitting cases.
Re: splitting cases
Re: splitting cases
Thanks. Seems I was lucky. But they were very tight.bruce_46 wrote:. Needs to come off. Be wary of the little T30 screws holding in the bearing retainer. Nearly every time I've split the cases I've had one stick, and torx head screws strip out easy.....
