Fzr 1000 exup valve issues
Posted: Thu Sep 05, 2013 8:47 pm
by jken91
Has anyone had any issues with the exup valve on the older fzrs? My bike is lacking power on lower rpms but once it gets to around 5000 rpm it seems fine. I ha a mechanic tell me that maybe the valve was having issues opening at lower rpms or that it was stuck open
Re: Fzr 1000 exup valve issues
Posted: Thu Sep 05, 2013 8:50 pm
completely. Pull your lower left fairing off, and do some
maintenance on the EXUP.
Posted: Thu Sep 05, 2013 9:30 pm
by jken91
And will this work for the 1988 fzr 1000?
Posted: Thu Sep 05, 2013 9:33 pm
Ahhhh ... No. The 87-88 "Genesis" 1k had no EXUP.
Posted: Thu Sep 05, 2013 9:43 pm
by jken91
Damn. I wonder what the problem could be then?
Posted: Thu Sep 05, 2013 9:50 pm
Check the battery voltage at 3k rpm. If the stator or regulator or battery isn't producing enough juice, you get a weak spark.
You may have lousy carbs affecting performance at the bottom end.
- Clean your carbs, paying particular attention to the pilot jets. They are difficult to get properly clean, and may need to be replaced.
Sync the carbs.
Adjust your idle mixture screws.
Posted: Thu Sep 05, 2013 9:55 pm
by jken91
Is cleaning carbs something a guy could do without any knowledge of carbs? I'm no where near wing a mechanic.
Posted: Thu Sep 05, 2013 10:00 pm
Yes, slowly, carefully. It's not hard, just finicky. There are a few threads here on carb cleaning; a quick search should get you some good ideas. Big 'gotcha' - you do NOT need to (or want to!) separate the carb bodies from the rack. Strip the jets from the bowls, inspect the other stuff from the slide covers. Leave one carb fully assembled while you work on the others - saves on "Now where does THAT part go?!" moments ...
Posted: Thu Sep 05, 2013 10:09 pm
by jken91
Thanks for the tips. Ill give that a try this weekend. Hopefully I don't mess it up too bad
Posted: Thu Sep 05, 2013 10:16 pm
by jken91
Another thing... I've been told there is a specific tool needed to sync carbs?
Posted: Fri Sep 06, 2013 11:24 pm
by coops
jken91 wrote:Another thing... I've been told there is a specific tool needed to sync carbs?
Yes there is. But if you do a bench sync (google search it) you can get it very close if your careful. Which is what I did. Then later on I bought a Morgan carb sync pro and checked my setting, it was close but not quite there. No noticeable performance difference, it will just idle better and sound a bit more syncd. The morgan tool is the one to get from my research. good value for money. cant remember what it cost, less than a hundered bucks maybe, which is what you would pay a mechanic to do the job. Good luck.
