Firing Order for 1987 FZR1000 is 1,3,2,4 from what I have researched. My main concern is are the cylinders numbered 1,2,3,4 from left to right? I am rebuilding my carburetors and I noticed that somebody had numbered the carbs and I think the person that numbered them got them wrong because they read 1,3,2,4 from left to right on the carbs. (Numbers were written with marker so I don't believe it was like that from the factory).
Thanks
Semper Fi
Firing Order
Re: Firing Order
You are correct for the firing order and the cyl numbering. Considering the carb jetting for the #2 &3 is the same, I don't think it makes any difference.
