plz plz plz need help with crank and cam timing marks on 2gh
Hi guys me again can someone plz send me pics of the crank and cam timing on 88 fzr 1000 2gh plz guys need it to run for work
Re: plz plz plz need help with crank and cam timing marks on
Hi thanx alot ant the crank must it be on the i or must i just put nr 1 piston on tdc
And the 2 marks on the cams sprockets must it show vertically up ?
if you re on the mark through the peek hole you should be at TDC you can look through the plug hole to see the piston is at the top, the marks should be at the top aligned with the marks on the caps yes
Hi thanx alot i got the crank timing thru the hole is H I T and i adjusted it in the I the cams timing must be adjusted so that i can put bolts thru the holes and the marks (dots)
on the sprockets must show almost up
yes I think the one cam is slightly off of the mark to put it all together on my 89' but when you put in the tensioner it'll all line up properly
