PDF Manual for 1000
ozzyfzr
Re: PDF Manual for 1000
Post by ozzyfzr »
The 90 model should have an in-tank pump with external relay, it should prime when first turning the ignition (light buzz), if in neutral with side stand up!
If your not getting headlight,horn and poor starting I would go to:-
Main ignition plug from key-barrell to loom under tank!! very problematic on these (go high resistance), the other is the main alternator plug in the loom LH side panel under seat (overheat with high resistance and melt plug!!!
Also these model bikes only like 12V and above, having any high resistance in the circuit will rob you of volts and cause all manner of issues!
With a voltmeter attached to the battery watch the voltage as you try to start! does it drop in voltage? Check every connection and I mean every connection! if looks iffy give it a clean and re-connect.
Hope it helps
Regards
Ozzyfzr
It looks fast! is it
Fizzinatorr
Level 6.5
Level 6.5
Post by Fizzinatorr »
The new relay did not do the trick...
testing fuel pump again now.
Fizzinatorr
Level 6.5
Level 6.5
definitely the fuel pump itself...i can't do anything to get her to crank
looking for a 98 Zx6r one....or a FZR 1000 one currently
Fizzinatorr
Level 6.5
Level 6.5
I am the Greatest Mechanic EVER
She's working....WOOOOOOOOOOOOOOOOOOOOOO!
Running smoothly.
Needed: New Battery, New Plugs, New Fuel Pump, checking each and every single wire on the bike
Annnnnnnnnnnnnnnnnnnnnnnnnnnnnd i'm on the road soon :thumbsup:
haunter
Post by haunter »
:bunny :banjoman :drumroll :rocker:
bweight
Level 4.0
Level 4.0
Post by bweight »
Sweet!
89 FZR 400
Custom Paintjob
600 plastics.
06 - R6 Shock
FZR600 Motor
Soon to be:
Broke........
