Most of the work is in welding the green sections off the diagram which is necessary with whatever you do unless you have gaps between each pipe(gaps will make it to wide for your underside).the wrap around is the easy bit once you have exit and entry prepaired.I have asumed you want cheep and to use stock headers as a starting point.Nemo wrote:By my original idea , I take it you mean the suggestion from Mossy to build a collector box ?
If thats the way , does anyone know a collector box from another bike that can be modded ?
Something maybe like FJ1200 or the likes ?
Cheers
other option is a yoshi style 4into 1 (already complete) then weld a one into two outlet onto that then away.
Can you give us photo of your existing headers so I can see how the 4pipes meet on the genesis.Its been 15years since i owned 1000t model.
