Thanks,
Ron Madurski
Sorry Razor he's got a 1000 but what you explained works the same way on the 89-90 Ik's with conventional forks.reelrazor wrote:Take the bolts out of the bottom of the outer fork tubes (allen headed bolt in axle recess-can see it thru hole in bottom of outer leg).
This can be done easily with an impact wrench. If no air tools available, then you will need to get/use an inner damper rod holding tool (the damper rod being the piece that the bolt threads into-and consequently the piece that keeps the two fork legs together).
Once that bolt is out you can use in inner leg as a slide hammer to pull the upper fork bushing out (in fact they won't come apart without that happening).
Here's the factory manual: Fork disassembly starts on page 31
http://www.fzrarchives.com/fzr600/600_m ... pt%201.pdf
sweekster wrote:[
Click here for the 89 1000 Manual and go to page 49 for an exploded view of the forks.
