Just bought a 94 Fzr1000!
Hey guys just got a beautiful fzr1000 last week with only 9k miles on it and perfect fairings. The bike seems to run great, just have a couple of questions about shifting. First off, is it normal for 1st and 2nd gear to sound a little clunky when shifting? Also I've read about 2nd gear going bad on these bikes (as well as ninjas and other sport bikes). Mine doesn't pop out of gear, but sometimes it's a little reluctant to go from 1st to 2nd. Do I just need to really make sure I shift it hard from first to second? Thanks!
Re: Just bought a 94 Fzr1000!
If you look at the end of the selector shaft there's a centre punch mark, the split in the arm should align with the mark. Also make sure the chain ain't too tight. It'll make gear shifts difficult and will eventually wear the output bearing with undue pressure
Yeah the shifter alignment looks good, and my friend who is a mechanic said the chain was on the tighter side, but there is still slack in the line. I think I just need to kick harder! Is it pretty normal though for these bikes to be clunky through gears?
My 92 TDM 850 (half an FZR engine but bored out a bit) is very clunky and that is normal for that...just takes a slightly different approach....you tried clutchless shift?
Think it's just one of those things from that era..
Be a while before I can try my FZR..
In the garage:
2012 VFR1200X Silver
1997 ZX7R P2 black
1992 TDM850 Mk1 army green
1988 FZR 1000 2RG White and red
1997 ZX7R P2 black
Cool I'm glad that it's normal. I don't do any clutchless shifting, never really seen the point with how easy it is to use the clutch.
I have a 89 fzr 600 and 05 r6 and they both clunky from first to second. Other gears are smooth. It quite normal especially for Yamaha gearboxes.
What weight oil is in the bike? The clutch is a wet clutch and the engine oil also lubricates the transmission. I've tried different oils (10W40, 20W50, etc ...) but my bike runs much better with the Yamalube 20W40. Both the engine and transmission run smoother with the 20W40. Give it a try and see if it makes difference. Also check your shift linkage to make sure it's adjusted correctly.
Don
1994 FZR1000
Tucson, AZ
1994 FZR1000
Tucson, AZ
I have a 92 exup 1000 and Use mineral oil in the gearbox, it gives smoother gear changes than synthetics and sounds a lot quieter on tick over.
Thats a really nice looking bike m8.Keep those tires connected to the ground.........dont they pull like bastards over 7k? I just put metzler tires on mine and I swear I can fell it snaking a bit in 2nd-3rd and fourth at wot .I LOVE THSES OLD FZR'S.I own an 83'Honda vf750f interceptor.I decidied to sell it and buy another fzr1000.
You can feel really the power once the EXUP valve goes fully open. Just remember to have feet on the pegs, weight forward and a good grip on the bars when you do it.dont they pull like bastards over 7k
Don
1994 FZR1000
Tucson, AZ
1994 FZR1000
Tucson, AZ
